They kinda do...
Also I like the idea of what i assume is a heavier Duty Tie rod itself as well...
I would not buy the kit I linked( $$$$$$$
) , would simply make it myself... But just was wondering the general consensus especially in relation to this thread topic, of flipping to top of knuckle...
I've got to be honest here. My tranny went down and I've had it out for about 1 1/2 months. During that time, I did a few mods, including the tie rod flip. I havent actually driven it yet!! Waiting on a couple little parts so it is still sitting. I KNOW it is going to drive better, partly because of the tie rod flip, but I also added 6 degrees of caster correction which I didnt understand 10 years ago when I first put the front end together with extended shackles. However, the flip also allowed me to get rid of the drop pitman arm, which I understand puts added stress on the PS gearbox and also throws the geometry out of whack a bit...
Also, because I was using a drop pitman, my drag link was almost horizontal. (one of the goals of doing the tie rod flip
OR drop arm is having horizontal drag link) Because I did the flip at the same time I got rid of the drop pitman, the net gain was zero!! No change... So the bottom line gain for me is getting rid of the drop arm... (plus changing all tie rod ends in the process)
Also in the down time, I put in a J20 PS gearbox to replace the very loose stock one I had. So, to be honest, there have been several changes in the steering system, so it isnt fair of me to say either way how much of a change the tie rod flip actually did. Personally I believe that replacing my worn out PS gearbox, and castor correction will improve things more than the flip / loss of drop pitman. But from what I have read, getting rid of that drop pitman is a very good thing.
On one hand it would have been nice to do these projects one at a time to see the difference each one made, but to be honest, it was good to have gotten the bulk of things done at one shot.
Now if the local shop would just get me my new front T case output yoke, I could get my baby back on the road and test all of this!!! AARG!!
