Timing Gear Change Out (258)
Rollbar
1986 CJ7 (1982-258CID). I have her '86 engine I will be rebuilding next yr after I get the 360 on the road.
Well, Peach drove home the other day and the CJ was running rough.
Since I haven't done much to the CJ (been running great), I rebuilt the carb (bbd), changed out the cap, rotor, coil pick up, coil, module. Ran good for a 1/2 day. Checked the timing and it was about 15* (from 9*). I advanced the timing to where it would just stumble and then backed off a little, checked timing and it's about 25*.
So, that leads me to changing out the timing gears.
It has been a long time since I have done this and the book is vague at most.
I'm going to do it next weekend and I have a few questions.
1. Which front valve is the intake, first or second (to the front of the Jeep, can't remember).
2. When I get this on TDC I will check the timing marks to see how far off, but, when I get it set on TDC, do I remove the old gear set and install the new set (pin make to pin mark/asterisk mark on gear) seeing that it SHOULD be on ZERO/TDC.
3. After it being on TDC I should set the damper on ZERO (hopefully it will line up), on the re-install so I then can set the timing right.
4. I plan on leaving in the distributor and just rotating the crank before removal. This should line everything up on the re-install so the dizzy would be set correctly, correct. Or would it be off due to the cam?
Sorry for so many questions/statements but it has been a while and I need some pointers.
Thanks again,
Jim
Thanks again,
Jim
