To Seafoam or Not to Seafoam?
76cj7chick
Old Time Jeeper
- Solutions
- 1
- WA
- 1976 CJ7 Jeep with a engine/tranny/wiring harness out of a 1988 s10 blazer 4.3l v6 with th700r4 automatic tranny and a cj7 Dana 300 transfer case with Novak adapter.
Complete wiring harness from the s10 blazer. Painted with HOT PINK Pearl paint with standard sized metallic halographic pink flakes. Painted by me -a newb. New rear, front and side three wire LED lights, New parts, new custom dash-by me And a lot of guidance from fellow jeepers and lots of prayers etc.... :p
Hi fellow jeepers!
Just wondering what everyones thoughts, experiences on using seafoam in an old AMC 258 i6 / 4.2l engine?
Background:
PO beat the $$#$# out of my now hot pink jeep.. The stock carter carb 1 bbl --was barely working. the engine had a lot of vacuum leaks, carb choke was gone. etc..
Specs:
I have a 1976 CJ7 with a old 258 4.2l i6 engine. and a new 32/36 weber carb. Problem is when i installed the carb I saw a lot of carbon build up in the intake manifold. Also, when I start the jeep black carbon spits out of the exhaust at first start.
Please let me know if you've had good or bad or indifferent experiences using seafoam to clean the carbon out of the intake manifold, off the pistons, etc...Did you experience any issues since using it. Does it actually work?
Hope to hear from our great jeep minds..soon... (that wasn't too cheesy.. I hope)
Background:
Specs:
Seafoam works great...run it for a couple of tanks to really get things cleaner.
