Torque Wrench?
Torque Wrench?
228jeeper
Ocean Springs, MS
86 CJ-7, 258, Desmogged, 4 speed T-176, Carter-Weber 2731, headers (no idea what kind), K&N Air Cleaner. Everything else stock as near as I can tell
Any suggestions for an affordable torque wrench and what size/adjustment range would be the most useful? Or would it be more affordable just to rent one? Thanks
What's affordable to you? 1/4", 3/8", 1/2" or 3/4"? Click or i-beam? How much torque?
I have 6 torque wrenches, a 1/4", 3/8", 1/2" and 3/4" i-beam and a 3/8" and a 1/2" click type.
I-beams are much cheaper then click (release) types, but never need calibrating and have been used successfully for many years! ;)
What will be your general application?
For right now, the application will be to replace the valve cover gasket. I have never owned a torque wrench, and I am not super mechanically inclined, but since I bought this jeep I am learning, trying to do basic stuff myself. Any suggestions? Thanks for the reply.
To use a torque wrench on a valve cover gasket (to factory specs) you would need a 1/4" i-beam wrench - a waste of money in your situation. The only time I ever use my 1/4" is when setting the preload on a pinion bearing...
To accurately torque that valve cover, you should use the "calibrated right arm"... :) :) :)
Snug all bolts down then retorque all the bolts just a bit more... The torque is "tight but not too tight". ;)
Use a nice bead of RVT on both sides of the gasket and you should have a leak free cover. On your AMC 258 i6 / 4.2l it is imperative that the cover is not warped or be bent at all.
I like that idea. More $ to spend on stuff other than a tool. It's an aluminum cover, btw. Thanks for the help
Aluminum covers are much more forgiving and seal better then stock ones, just use that "calibrated right arm", be careful and you should be fine.
i keep a SHARPIE marker around all the time for stuff like that.
snug it mark it at a 12 oclock position and turn it to 3 oclock or 1/4 incremements
it helps me
When you do need a torque wrench, or a moment wrench as my physics prof called it, get a decent one. You will be together for a long long time. I like the click type. I , personally, don't think precision is as important an consistency. The idea is to have every thing the same amount of "tight". that said, the first one should be 3/8", suitable for torquing head bolts, rods, mains and clutch bolts. I will try to torque everything I can find a torque rating for, I have even torqued spark plugs. in aluminum heads.
CJ is dead on valve covers are a question of feel, resist the urge to tighten them. :D
