Tranny chatter?
- Solutions
- 1
- Springfield, Missouri-U.S.A. Earth
- '85 CJ-7, 258/4.2L 6cyl. Bought new in 1985. Full cage, Warn 8274 winch, Ford 9" rear, front/rear Detroit Lockers w/4:88 R&P. T-5 tranny and 4:1 t'case. 33X12.50-15 BFG/AT, MSD ign, on board air---
Go too tremec's website
Go too FAQ's
T-5 lube ...world class t-5's synchromesh (prevents bushing and synchro de lamination)
T-5 lube.... Non world class t-5's dexIII (no laminated bushings or syncros)
Either will work one is less expensive.
Wrong-
The WC T-5 uses ATF as per section 2, item 4 of the Tremec PDF.
http://www.tremec.com/anexos/TRSM-T5-0510-R1_173.pdf
AMC said to use DexIII, and burn'd up allot of T-4 -5 trannys(the WC T-5 is not anydangthing like the Jeep T-5 )
Borg-Warner would not back AMC on this issue and AMC had to pay for the burn'd up units.
That is why the 'stink-oil' was developed.
Somewhere in history there is a TSB warning NOT to use ATF in the T-4 /5.
Penn, Synco is good and I have been run'n Valvoline syn 75W-90 in mine for many-many years.
Stay with the Penn syncro.
