Tranny leak and oil leak
carolinadog
- Columbus, Ohio
- 1978 Cj5, 258 Striaght 6 with a 3 speed manual tranny. Not sure about anything else.
I have a 78 CJ5 with a 256 striaght 6 and 3 speed manual tranny. I have a tranny leak coming out of the front of the bell housing. I have replaced the input shaft seal and still have the leak. I believe that the tranny is a borg warner. What am I missing?
Also I believe that the engine is from an 80's model Cj5 because it has the plastic valve cover. The oil leak is coming out the top of the valve cover from the vent hole that used to connect to the air filter. If I replace the plastic one with one with baffles in it will that take care of the problem or is that a sign of bigger problems?
Any info will help. Thanks in advance ya'll...
