Trans Question.
None that I know of.
If you use an early Jeep 4.02 first gear T-18 you would need to mod the AMC 150 b-housing and driveshafts
If you use a later Jeep T-18 6.32 first gear you would need an adapter between the Transmission and tcase, mod the AMC 150 b-housing and driveshafts
ford T-18 you would need to do all the above plus a Transmission rear output shaft.
Best way would be to buy a package deal bell, Transmission , and tcase. Then all you have to mod is the driveshafts.
You won't use first gear on the road with a 6.32 T-18 even with 3.54 gears.
You didn't mention driving off road, only on road. You would be ahead of the game if you just re-geared your axles to match your tire size.
You won't use first gear on the street unless your towing. So the T-18 and T-150 are basically 3 speeds with the same gearing for street driving.I just think it would have better driving manners between 1st and 3rd not to mention the real low first gear I think would work better with the diff ratio I have.
For around town use and mild trail riding the T-150 is a good Transmission . The T-150 with 33” tires I would go with 3.73s or 4.10s for better road/trail use.I'm trying to be realistic about it. I live in town and enjoy driving the cj around town. But, I'd like to do some mild trail riding also. I've considered just swapping axle gears and will probably still do that. The low first gear in the T-18 appealed to me because second gear is so close to my current first gear. If I swapped a T-18 into the cj with the 6.32 first gear then maybe raise my axle gearing to say maybe a 3.43 instead of the current 3.54 setup, the low first gear in the T-18 should handle the higher gearing but still be trail friendly and improve highway driving as well as around town. Just my thought. Do you see any holes in this theory?
Another Transmission option would be the NP435,with a little lower 1st gear. I think your current rear gear is good and your can add those lunchbox lockers to them. You might have an issue in the steep asphalt hills, as I do around the 8500 ft level. There is always the low gear Transfer Case addition to help in the rocks.
Sorry to say-Don't have a clue as the their value. :dunno:
Post up pictures of the inside so folks here that do know can help you.
Also, if your going with the 435 and spending over $500 to adapt to the Transfer Case I would recommend finding a 2.62 low range Dana 300 to replace the 2.03 low range Dana 20 .
$50-$200
I was thinking in the same ballpark. We'll see what kind of deal he'll make me. I'm kind of liking the $50 range at this point.
