Trans shift cover
Trans shift cover
DIG
Knoxville TN
In the shift tower, there is one bolt that is longer than all the other ( I am talking about the shifter assembly cover that bolts to the top of the Transmission ) on a T-150 . Does anyone know what size and thread pitch this bolt is?
Update, i am making progress on the CJ I still have to grind the header flange alittle more though to clear the head bolt......then its wiring the motor back up and runing vacuum lines! Anyone have a vacuum and wiring diagram of the AMC 304 ????? And the ignition module..!! :chug:
Can't help you on the bolt but what vacuum lines? Unless you are hooking up emissions there will be only one for the brakes and one for the distributor. Are you putting the emissions back on?
What is the ignition module off of?
Trans 81 CJ8
