Transmission rebuild....or just a clutch or shifter issue???
Turtle71
I wanted to finally take the Jeep for a drive to see how it behaves and what other issues we may need to address. I wasn't sure about the condition of the Transmission fluid, so i decided to do a drain and fill on the T-5 . I did alot of research on which fluid to use and came up with many answers. In the end I decided to go with 2 quarts of Pennzoil Synchromesh that was recommended by several people who had great results, one of which was a guy who rebuilt many T5s as a business.
I have driven it previously, but only for about a half mile. Each time, I was able to from 1st through 4th at the most, given the short distance. This time I was able to drive it for a few miles. Shifting was pretty easy, but I suspected a worn throw out bearing based on a familiar noise I was hearing. On the way back, I was stopped at a light and when I started going forward in 1st, I heard a loud bang and it seemed to come out of gear.
Pulled over and was able to get it in 1st a few times and start to go forward, but it would either make a bang noise or grind. I was able to get it back home by starting out from 2nd gear. When I had it back in the driveway, I tried to use 1st and got the same results. I also noticed it was difficult at times to find reverse, but I would eventually find it and it would work fine.
Has anyone had similar experiences or have any idea what may be involved??? Complete rebuild of the trans? Or will I be lucky with a clutch related issue?? Any help or advice is greatly appreciated.
