trying to fix fuel gauge
dalefan88
Crazy Sr. Respected Jeeper
ada,oh
79 cj5 258, t150, dana 20 transfer case, dana 30 front, 20 rear,warn hubs,2.5" procomp lift,teamrush,msd box,mc2100 carb,hedman header,clifford intake,optima battery, ford shock towers.
ok im messing with the fuel gauge today. i moved the ground to a good ground on the sending unit and nothing. so i got under the dash and played with those terminals. if i put a full 12v to the s term it goes to full. if i put the wires back on the way they should it goes right back to empty. so does this mean i got a bad sending unit? i hate some electrical work :mad:
Lol, how much gas is in the tank?
Check me post of useful stuff in the misc section there is gauge info there to t/s the gauge itself.
Check me post of useful stuff in the misc section the is gauge info there to t/s the gauge itself.
i was out of gas and put $20 in it so i dont think its full. i have two things im going by and sure that they are the same as yours. i just hate electrical.
It might. You know if you put 12v and the gauge moves that you don't have any problems with the gauge, ground, or wiring. A couple of things could be wrong. The float could have a crack or it could be stuck somehow. You'll have to pull the tank out for that. That's what happened with my tank.
