Hoping this is an easy fix that someone can help me out with....
Turn signals do not flash when engaged, however they do flash when the hazards are engaged and do illuminate when lights are turned on.
Any suggestions?
1982 CJ7
If you look at your fuse block you will see two round silver things they are your flashers. Turn on your hazards and you will here it clicking the other one you need to replace.
I do have the two round sliver relays for the configuration, and I thought (hoped) that would be the case. Since the Hazards worked, I simply swapped them... Hazards still work, and Turn signal still does not work.
I think that would mean that both relays are fine, but another issue elsewhere, correct?
Some later model Laredo CJ's had the turn signal hanging on a 90 deg plug Yellow wire, Red w/White trace.
Area behind the clock/headlight switch.
No idea why the fuse block wasn't used. Mine never had the packard connectors installed, either. Wasn't the PO's doing. Went bad and bought a LOUD one as a replacement.
Do your brake lights work? Hazard was fused separately from turn, IIRC.
Bulbs installed incorrectly, or tired sockets causing the bulb to tilt can do some odd things to turn/hazard/markers as well.
If all the hazards flash, it's not a socket ground issue.
All bulbs work (can see them light up when the hazards come on).
Brake lights work when brake is pressed
All lights (Front and Rear) work when the main light switch is pulled on.
Will next investigate the comment "Some later model Laredo CJ's had the turn signal hanging on a 90 deg plug Yellow wire, Red w/White trace."
