Twin stick removal
Twin stick removal
TroyaCantrell
Old Time Jeeper
Orangevale, CA
1966 CJ 6, Buick V6 Dauntless,
Dana 44 rear, Dana 27 front
Trans GM SM 420
First Gear ....... 7.05
Second Gear ... 3.57
Third Gear ...... 1.70
Fourth Gear ... Direct
Dana T-case (twin stick)
1970 Glass dune buggy. Short pan 1600
2008 Chevy HHR SS
The set screw would hold the shaft in place, if your set screw is missing the shaft should slide out, maybe spray it will PB blaster first.
Thanks, soaked it down last night and worked it loose. Got the sticks out and the cover. Now I just need to dress up the cover a bit and get it all back installed. It is a bit rough but will be covered with carpet anyway.
Thanks again for the help.
Troy Cantrell
Build thread - '66 CJ6 :
http://www.jeep-cj.com/forums/showthread.php?t=15075
