Engine Unknown Part, Please help Identify (engine/fuel/carb related) AMC 360
ColoradoDerek
Colorado
'73 CJ5, AMC 360, D30, D20, T150, AMC 20
Hello! Good day to y'all!
So, my fuel lines were leaking (dry rot) and I got some new line to replace them but while taking off the old lines... something happened!
This part popped out of my engine! My engine must have been telling me HEY, GET THIS TOO!!!! The only problem is, I have no idea what it is to get a new one!
I went to AutoZone and they had no idea what it was (they started searching google and I was like "uhh, I can do that at home") Turns out, I CAN'T do that at home because nothing I search for shows me any pictures of a part that looks like this one.
I'm hoping you guys can help me out with what I need to buy.
Info:
Motor:
AMC 360
Numbers on the part: ACC 9219 and 8160219 in between 2 arrows pointing up.
I have also attached a picture of the part. It was located behind the carb, but connected to the carb with a fuel line and it smells like fuel.
Any help would be greatly appreciated.
On a side note, if anyone remembers me from my bi-monthly posts asking for help, I also got my tie rod and it looks like it will be the right one. REAL CLOSE to being able to drive her again. I still have not gotten the rear diff. off to find out my gear ratio though so unfortunately it still has 35's on it. Really excited to get that diff. off to find my ratio so I can find out what tire size I should be using but its been over 100 degrees here for like the past 2 months and I just can't work on it where it is when its that hot. SOON though.... SOON.
ALSO! I have one more question that isn't really related to my Jeep but rather the app "Tapatalk" which I was trying to do this post from but couldn't. The reason I couldn't was because it requires me to choose at least 1 TAG and from the Tapatalk app I couldn't figure out how to add a tag. Does anyone know how and could tell me?
THANK YOU!!
Solution
As it seems to have a rubber grommet on one end and hose fitting on the other a really odd PCV valve? Grommet end on the valve cover and hose end to the air filter or carb. After googling AMC 360 PCV, it looks kinda like ones that fit on the intake manifold.
Solution
You are the MAN.
I think that is it!!
I didn't realize the rubber part and the metal part were 2 separate things.
I bet my actual PCV valve is fine and its just the rubber grommet I need to find.
I will start searching!
I found it I think!! so happy! There are so many of these things and they all look the same but this is where my money is:
https://www.jegs.com/i/Omix-ADA/440/17402.05/10002/-1
