Vacumn Diaphram for Choke
Allen9878
Central Wisconsin
1980 Jeep Cj5 Renegade
I258 1987 Engine
Aisin Warner Ax15 Transmission
Dana 300 Transfer Case
Hey I'm figuring out the vacumn lines for my carter 0268 2 bbl on a AMC 258 i6 / 4.2l I6. I do not need emmissions just need the barebones setup for running good. Where does the Vacumn Diaphram for the choke go to in a non emissions setup? Picture Included
Also It has an electric choke, where does the wire connect to for that?
There should be a vac. scource on the carb. for the diapram. If memory serves right the elec. choke gets a keyed on "hot" feed. Just my 2 cents.
Anyone specifically know which port it goes to?
There should be one port on the throttle plate to get vacuum from other than the distributor vacuum advance signal.
    Best for votes
    on specific items
