Viewing the World from flat on your back
yea there very expensive but if there is a place around that works on heavy equipment you can get in good with them and borrow one like i do :)
Brian, it (torque multiplier) would work. I have in my head a big turnbuckle; pretty easy to get here is the Gulf ship-building trades. I have more experience with 'em than I need, or want. Once I get one laid out along the length of the steering shaft, an idea will come to me about how best to attach to exert the force I want. It will be fun trying to make a tool out of parts that seemingly don't go together.
Yes that is the inner seal leaking (out of the bottom weap hole)
I have never seen a gasket in there, just wipe a thin layer of rtv and your good to go.
Old Dog, I am pulling back to a new position; new one-pieces!
See my last post, and thanks.
Dhugg
By the time the new axles arrive (UPS is gonna hate me), I'll have the brake parts cleaned and the backing plates fully populated with brake parts.
The shinny spot on the axle is where the seal rides (I think from the pic) if it is still smooth it will be ok.
Do NOT put any parts on the backing plate as it gets shandwiched in between the axle flange and the bearing on the one piece axles. Its a lot easier to press everything together that way.
please take lots of shots of the axle install. This is about #3 on my project list, I can't wait to see how this turns out.:popcorn:
You got it, IO. I'll cover every change with a photo, including the trip to the local machine shop for bearing press-on.
DHugg
DHugg
See if you can take a legible shot of the instructions especially the shimming and adjusting the end play.
I shall speak kindly of you to people you don’t know, when you are not around.
Where did you order the axles?
IO, I actually had to hunt a bit for Superior or Moser axles. Found them here
Superior Evolution Series AMC20 One-Piece Axle Kit (76-81 CJ7, 76-83 CJ5)
at better than two other places.
I downloaded a PDF that is supposed to be the install, a 2-pager.
DHugg
Update on the attached PDF:
I just got off the phone with Superior Axle & Gear concerning the measurements in Chart A in the install guide. I could not match the axle side lengths of my 1980 CJ7 AMC20 rear axle with the numbers for kit EV20E.
Superior tech support (BTW, we started out speaking English, and finished the conversation that way) confirmed that the Length B, PAX side, for EV20E has a MISPRINT.
There was a "3" inserted instead of the correct "2", making the Length B, Passenger side, measurement 24 3/4 inches. The EV20E kit is correct for my 1980 CJ-7 AMC 20 rear axle; this is called the "narrow spread" or "narrow" axle.
Don't want to lead anyone astray, even by accident.
DHugg
