Wagoneer Axle swap Brake Question
YUKON007
Quick background: I have a 1982 CJ7 with Power brakes, front disc and rear drum, I'm in the process of installing Waggy D44s with front disc and rear drum. I know this swap is covered in detail repeatedly on the forums, but everyone seems to stop once the axles are mounted and back under the jeep. My question is concerning brake lines and proportioning valves:
1.) Since I'm already frame-off I want to run all new brake lines. If I get a CJ7 pre-bent set from inlinetube.com will it be able to handle the larger Wagoneer Dana 44 brakes? I believe the wagoneer ran a large diameter rear brake line than the CJs. Obviously it is cheapest and easiest to buy a system from inlinetube made for my CJ, but I'm worried the smaller diameter tubing might effect braking power?
2.) Can I run a stock CJ7 proportioning valve? I'll need to order the disc front and rear drum style, but will it handle the larger brakes on the Wagoneer axle? If I run a wagoneer proportioning valve then I'll have to either run larger brake lines or get adapters to match inlet/outlet sizes.
3.) I need a larger MC, I was thinking of stealing a MC and booster set up from a late model YJ, they run the same size brake lines to the proportioning valve, so theres less of a headache there. Cheapest easiest way to do that? I see online theres a guy selling an upgraded MC and booster set up that supposedly bolts staight up. Brakes
Ideas? I know people have tackled this before. What set up are you running? Notice any change over stock? Any tried and true methods? Anyone have a clear parts list that they know works?
