Wagoneer?
Wagoneer?
jzak
Old Time Jeeper
Pittsboro, NC
Hey Guy,
I know this is not exactly a CJ topic, but I figured maybe some of you may have experience in other jeeps. So I always thought about maybe buying an old Grand Wagoneer, but with the value skyrocketing I figured i was priced out of the market. A couple days ago, I found this craigslist ad for an 87 Grand Wagoneer for $3,200. Its definitely rough around the edges, but its running, no serious rust, and all the windows and electronics work.
Any thoughts? Is it a good price? Are there any massive mechanical issues with Grand Wagoneers that would bankrupt me?
Thanks!!
lol its a jeep it will bankrubt you one way or another. I like waggys and have fond memories of them growing up. you should get it.
:D Very True! Thanks for the feedback!
So, I did, but I was looking for a parts rig, I found out about the only thing I can use is the rear diff, I was hoping for more, the front difis a closed axle, I don't want that, I wanted a GM Turbo 400 Transmission , seems that the one in the 73 is different from the other's, so it was a bad buy for me in regards to using it for a parts rig, now I have to decide if it's worth it to keep it for just the 1 44 rear axle or sell it to someone that wants to do a restore, it has all the stock equipment on it, including the closed front axle, the GM Turbo 400 that I was hoping to use is the wrong one that I need, it was a bad buy for my needs, now I am at an impasse, do I sell it or restore it.
Sent from my SM-G950U using Tapatalk
Wow it has a closed knuckle 44 up to 73 that’s crazy, if it’s running I think it’s better to sell it whole or restore it and find one that’s not running for parts
I always thought they were pretty cool. If possible fix and save it.
What were you hoping to do with the Transmission ? Does it have the Dana 20 or QuadraTrac tcase?
It's should a be closed knuckle Dana 30 on a 73.
I need to go get a pick of that axle and post it, I will here in a bit.
From what I have read, 73 was the last year for the waggy 44 closed knuckle
Here it is
Looks like the front is a Dana 30 closed knuckle to me. And the rear a 44.
Fairly sure its a Dana 20 , I was hoping to use the GM Turbo 400 in my CJ7 , but I was told its different that the GM, AMC and BO GM Turbo 400 and that it won't work for the CJ, I haven't pursued that yet.
No telling what they did back then but sounds strange since it’s bolted to an amc motor, I wonder if it came with a factory adapter plate
The Novak Guide to the GM TH400 Automatic Transmission
Here is the link on the info, The GM Turbo 400 had a factory adaptor for the Jeeps, Im not sure about why it wouldn't work in the CJ, I was told it has something to do with the overall length after adapting everything, still need to do more research on it.
This is input from another user here on the GM Turbo 400 .
"you can mate it to the AMC 304 using the 360 adapter, but you would need the unique AMC 304 flexplate that goes with the crank adapter shown in the picture. AMC V8’s are externally balanced. You could use the 360 that’s coming with the Wagoneer. It will bolt right in where the AMC 304 goes. I honestly don’t know about adapting to the Dana 300 though. These oddball GM Turbo 400 had long output shafts. It just wouldn’t be worth using if you had to swap shafts in the GM Turbo 400 ."
So more research I guess.
