Warn 8274 Winch?
Warn 8274 Winch?
Thank you for that. I kept coming up with the same answers time after time. Most searches came up with information on the older models. Probably wasn't holding my mouth just right during the searchs.
That is about the date range I expected. For a 15 year old winch it's in pretty good shape.
HH, congrates on a nice buy on that winch. All my 8274's and others I have seen have serial numbers and manufacture code. Probably 1970- 80'ish.
I guess some folks got the rejects with no numbers. mike
HH-Those 2 roller fairleads look pretty much the same to me.
Is the bolt spacing the same between the HF winch and the Warn fairleads?
Tell me about your front bumper/winch mount. Do you have any other pictures of it?
I have one of these on my CJ and one on the bench I picked up a couple months ago. If you need pictures of the commercial mount let me know. the loose one was Jeep mounted rather than dealer or owner so the tag says Jeep rather than Warn.
Lumpy - Both fairleads are virtually identical right down to the bolt holes. I've got other pictures but the winch pretty much covers the plate completely up. The plate looks pretty much exactly like most of the other plates on the market right down to the thickness of the steel. I.E. 1/4" flat plate, the back bent up ~2", the front bent up ~4" with the fairlead hole in it. I made my bumper as you see it with a cut out where the Fairlead attaches.
My plan is to attach the winch bottom bolts with the fairlead attached. The place drilled tabs of the correct height to the top attachment points with the attaching bolts. and tack it well to the plate. With the winch removed the tabs will be welded up along with side wing fillets to strengthen the tabs and reduce flexing.
mstar & IO - Thanks, there is something about a Warn winch that just screams, "I belong on a CJ." Normally there is no way I could afford this type of winch, but this one was worth digging a little deeper than normal for.
mstar - Rejects! :) NOT!
:) I know humor when I see it. I was funnin' back.
Edit: Or as I re-read your post maybe you were serious, I have heard about businesses that would grind off their name and serial numbers on products that didn't quite make the grade to sell them at a discounted price or as seconds. Guitar manufacturers are well known for doing that sort of thing. Did Warn sell their rejects at discounted prices?
HH-Instead of 'tabs'. Why not weld a full length plate to the top of your plate?
OR-Go with a full size plate behind(doubler)the one you have now.
Hint-Make sure to use GD 8 bolts and nuts for the mounting.
Well, I'm thinking about air flow with some consideration to weight. The bottom bolts will have a full length plate around the fairlead from side to side. The tabs won't be a minor thing, they will be substantial along with the side wings and the wings would be the key to the strength of the plate. While searching for plate designs many were similar to what I'm thinking of. A full width plate would actually be easier to fab up.
I did consider the doubler plate type setup. Other than giving the plate front impact type strength it really would not increase the tendency for the plate from flexing front to rear along the bent angle across the front or front to back flexing. The only way to add that sort of strength is to ad the side wings angled back ~45*. Things like this are far more difficult to explain than they are to do.
Grade 8 bolts are a given or most of my CJ projects. The winch actually still has it's factory bolts and nuts, well I guess you could call them nuts, big square flat on the bottom nut like things.
Never had an airflow issue with mine. I don't run a winch cover.
The only concern with your custom bumper would be clearance of the winch motor on the Warn to the grill face.
My factory Warn mount, only gives me about 3/8" space between the grill and the winch motor. I have 9" from the backside of my mounting plate to the grill.
Did you ever do a writeup about your homemade front bumper?
I'm sure I did way back when I first got the CJ and came here. The bumper is made of 2"x6"x3/16" steel tubing with recovery points, a receiver and a notch for the fairlead. This served two purposes the winch can sit lower and the bumper ride ~2" higher. The bumper is very stiff. But even with the tapered sides it is a little bland. Today I'd angle back the tapered sides and possibly a tapered edge on the bottom. Since the original jeep bumper is a channel slipped over the front of the frame ends with bolts holding it in place my bumper actually increases room for the winch. My bumper is placed against the front of the frame with several mounting points bolted to the front sides of the frame. Essentially giving almost 2 extra inches for the winch to live in. Until you mentioned it I hadn't given the advantages of my mounting system a thought.
Airflow - Originally I never gave airflow a second thought. The big blunt front with a wide open grill area seemed like enough area for air flow. Since then there have been post after post about CJ's over heating and vapor lock problems, especially at high elevations and moving slowly. Several posts here and other places mention the size of the 8274 and blocking air. Couple that with the V8 under the hood gives room for being conservative with preserving lots of air flow.
Do you recall what the title was on your front bumper built?
My search 'FOO' sucs.........:laugh:
When you rewind that cable. Do it under some load/drag. Apply some parking brake and then guide the cable onto the spool. I have found silicon spray to be a great cable lube as it is dry.
Nicely done! :notworthy:
Many hours of work for sure, and it clearly shows. :chug:
ONLY use silicon spray on the cable. This is a trick I learned when I was driving HD wreckers haul'n semi's. Dirt won't stick to the cable and you can hose it off.
Add 1 or 2 clicks of p'brake when you wind the cable, be sure to put it in tight layers on the spool. That AMC 150 ' of cable will fill the spool........
Do you use some sort of tool to direct the wire on the spool? I've considered making a short rod with a loop on the end. Hook the loop over the cable to control the placement or wrapping is neat, tight and even. Or am I over thinking this?
You can see all the holes in the winch plate giving it a Swiss cheese appearance. Those were welded closed. The project really did go well, I'd hate to be an elk or deer or vehicle for that matter to get hit by it. It's likely the bumper will crush most anything that gets in the way. The negative is, it's so flat and uninspiring.
I put the engine in a fast idle setting with a touch of p'brake. Standing in front of the Jeep as the winch is winding. I use my boot or a HEAVILY gloved hand to guide the cable.
I have also used the curved end of a pry-bar to layer cable.
Nice looking solid bumper.
I remember you doing a write-up on the rear bumper.
Nicely done for sure! :cool:
Well made and functional with protection. Nice work
