Warn 8274 Winch?
HackFabrication
Old Time Jeeper
- Canton, MI
- 1976 CJ5,
2020 Grand Cherokee Summit,
2018 GMC Sierra 1500 SLE Regular Cab Shortbed
Nope. Spool just runs on that plastic bearing/bushing. You can add a bit of grease to it. Or:I do have one question though. When I took the fairlead block off the side plate holding the spool on came off. After looking it is fairly obvious that the winch is designed to do that. What I want to know is there any lubrication needed on that side. It appears that there isn't a true bearing on that side, just a plastic sleeve type bearing surface. Am I missing something?
I drilled mine for a zerk fitting, and about once a year put a 'shot' of grease in it.
^^^ Do this. There is a good write up on that site I posted about how to do it. I'm not going to go that far on either one of the 8274's I've got. Same with adding the drain/fill plugs.
FWIW, my CJ5 with the 5.0L Ford doesn't have any cooling issues with the 8274 out front.
