Engine Water Pump
Engine Water Pump
rustonrust
Florida, USA
1986 CJ7 Laredo
Anyone purchased a water pump online recently? I have heard there are many different versions that fit differently and need to compare side by side with old pump. Wondering if this is true and I need to take old one into shop to compare before buy? Or if ordering online has worked out for others. 85 CJ7 with AMC 258 i6 / 4.2l . Thanks.
Solution
The easy way to tell is what type of belt system you have.
V-Belt = Standard flow.
Serpentine Belt = Reverse flow.
You probably going to need to know what direction the water flows. I got mine at napa
I've bought a ton of em off Rock Auto over the years never an issue. Just get a quality brand
I don't think I've ever owned a serpentine belt CJ
Anyone purchased a water pump online recently? I have heard there are many different versions that fit differently and need to compare side by side with old pump. Wondering if this is true and I need to take old one into shop to compare before buy? Or if ordering online has worked out for others. 85 cj7 with 4.2L. Thanks.
Hi yes, there are two types of pumps for sure if you are working on a AMC 258 i6 / 4.2l ? I removed mine took some pictures of it, then compared it with the pictures at the online stores. I found out the hard way, and have a new one- not matching my AMC 258 i6 / 4.2l somewhere sitting.
I just put one on my 81 from FlowKooler, reverse flow for Serpentine belt. Beautiful build quality, CNC impeller, higher flow, Japanese casting, CA company. Super fast shipping and nice Website
I just remembered about the below thread.
Yes indeed, those FlowKoolers are great! Old school engineering and build quality. They even use bearings on BOTH sides of the shaft!
Yes you will need to check the direction of the water flow. I managed to buy the correct one online. Take a photo of the one you have on you jeep from different angles (take it out of place for better pictures) , then compare it with those for sale online. No big deal, you will see the difference and you will get the correct one.
