Engine What did this Carb belong to?
PSully76
Richland, Mississippi
76 Cj5 258, T150, D20, D30 front, AMC20 rear.
I haven't had issues
A Rebuild. I want to completely disassemble it, get a decent rebuild kit and figure out what all parts i need to convert it to an electric choke. It seems like the choke flap/rod is bent as well. I was wondering if i could get a cheap chinese carb and use the hard parts (I.E. choke flap/rod, accel pump rod) and use them as replacements for this carb.
It was hard to find a Mc2100 with 1.08 venturi’s so i’d like to do all i can to make this work.
If you use a manual choke it might be a means of foiling those who steal jeeps. My 2150 has a manual choke and takes very little time to have enough manifold heat to shove it back in.
Well here’s a little update; I reached out to the tech support guys via email at Mikes Carburetor parts. By the looks of this one they seem to think it came from a ford 330ci engine. Those engines were specifically in industrial equipment or Ford’s heavy duty trucks. The guys at Mikes were able to hook me up with the correct rebuild kit plus a few extras.
Also this is probably the simplest 2100 carb i could’ve ended up with. There’s only one vacuum port and is a manual choke model only. There’s not way to convert it to electric choke.
Yes sir! I’ve combed through a few of those and it helped me narrow down what exactly i needed. I’ll post more pictures when it’a fully rebuilt but I’m still waiting on some parts that are in the mail!
$20.00
  10.0%
