I lost RPM signal from the ECU. Sent a little extra fuel out the exhaust and BAM! The detonation of the fuel in the exhaust was enough to give me a heart attack.
Just sent the unit back to Holley. Hope to be back up and running next week.
Sent from my Pixel 2 using Tapatalk
Under some type of warranty ?
.....The detonation of the fuel in the exhaust was enough to give me a heart attack.....
I had a 78 Bronco that backfired like that - blew up both mufflers.......
Yeah, under warranty...they cover shipping to and from.
That's the first thing I checked when I got it home. Exhaust was still intact...I have glasspacks, so not enough restriction to bust through.
I have one of their systems also. What is the warranty ? I don't think I have come across it.
No clue actually [emoji23]
I bought it this summer, but they never asked. I bought it from EFISystemPro, but did the warranty call with Holley.
Thanks I actually got mine directly from them.
I had a MSD fuel pump that rolled off the counter and broke the hose barb. I bought it earlier this year, lost the receipt, sent it back and Holley replaced/fixed at no charge. Good folks to deal with.
Had to replace a headlight that gave up the ghost on my way home from work Saturday.
Sent from my SM-A405FN using Tapatalk
Evidently spun a hub on the 20 in town the other day
Thought maybe it was just a loose yoke nut...no such luck
Never did pop that I can recall...had always heard that usually there's an unmistakable crack that tells the tale
Replaced my cracked windshield washer reservoir. Amazingly, the job was fast and easy. I got the old one out and new one installed in an hour.
Where did you get the new one ? New pump was in it ?
Built this rear bumper for my son’s’85. Used the stock carrier and modified it to not directly hang off the body.
Looks pretty serious !
I got the reservoir from omix, it has an included pump and I will keep it on there till it goes out. There are several aftermarket companies that make just the pump too. Summit has at least 5 different replacements. The only reservoirs I found are omix and crown. Both are generally garbage brands but omix seems slightly higher quality to me when I have to go with one or the other.
I reluctantly got the Omix reservoir about 10 years ago with a new pump. It has been surprisingly good and has not leaked or stopped working. I did have to use some silicone sealant when I installed the pump. But flawless for 10 years. (Knock on wood)
Inspired (and helped) by what some people here were posting about steering wheels I started improving mine.
I received a worn amc center logo from mdeluca and installed on my wheel (which didn't have one).
Next up I'll be adjusting my wheel so it points straight while driving diwn the road (currently its off by 30-35 degrees).
Sent from my LM-Q720 using Tapatalk
Got my MORE HD steering box bracket installed today. Probably really didn't need it because I doubt I will ever run this with 35 inch tires, but maybe 33s eventually. Won't have to worry about it for now on.
Great bracket...
I've got mine all prepped, painted, and ready to install. Also got a new steering shaft bearing.
    Best for votes
    on specific items
