Nothing. It rained most of the day. Went to lunch with a buddy. It was a great day
So what did I do this weekend? Well I finally got my freshly rebuilt. T 18 Transmission from Novak mounted up to my AMC 304 and the Dana 20 Tcase mounted up to that (Which required using a BFH to gently persuade the exhaust pipe to cooperate). Then I had to spend the next four hours fighting with the Crossmember. Everything you read says all you do is slide it back a set of holes and it will mount right up. But it’s my Jeep, so of course it wouldn’t be that easy. Every mounting hole was 1/4 - 1/2 inch too wide. It was almost like my entire frame was squeezed together slightly. Ended up having to take the welder to fill in all of the holes in the crossmember, and then drill new ones. Oh, and I had to do the same with the transmission mounting holes. And then of course, three of the six mounting bolts, stripped out due to 44 years of corrosion. Fortunately, I was able to drill and tap them all to a larger size. So after about six hours, total, I have the guts back in the jeep. Now I just have to get the twin stick shifter mounted, the new tunnel plate cut and mounted, and get new measurements for both driveshafts.
Luckily CJ They are only 3 hours from my house. I have a friend with a truck and a trailer who has already said he would drive up with me to pick it up. Jay said it should be there sometime in mid June. So it's going to be my Birthday present. Counting the days.
Whoo hoo! :chug:
Haven’t been driving much lately. We’ve gone from a severe drought to showers for several days now. I did grease the drive shafts and front end yesterday. Need to do some checking on things since I have a big trip planned in July-August. Need to get motivated i guess.
I cleaned a wheelbarrow full of mud off of the underside and then pressure washed everything. Spent two days on the trails at the Bantam Jeep Festival in Butler, PA.
Yesterday actually. Recall my front passenger squeal! Brake drag. Pads and rotors not enough. So i replaced brake hoses and calipers on both fronts yesterday. 1980 brake hoses be fused w rust. Breakfree works.
