What Gear Is Missing in Photo
studdy05
Dermott
'54 CJ3
Or a nice Warn Overdrive with the correct spline and gear.:)
I'm guessing you'll need the 26 tooth gear.
But...you might need the 29 tooth gear.
Be aware of the 2 possibilities.
Especially when dealing with a Jeep in boxes.
I bought the 26 tooth gear. After I rebuilt the T-90 and 18 and mated the cases I went to slide on the 26 tooth gear and the splines were slightly too fat (the 18 has slender longer teeth) and it wouldn't quite mate up. It also looked like it was going to be off center ever so slightly holding the gear in place.
Turns out the T90 is a T90 J that maybe had a side shifter, so its not original to the Jeep, but it looks like the 18 is.
Long story short, if its not the 26 tooth gear, it has to be the 29, right?
Thanks for the tip, too!
$35.00
  17.5%
