What is this can?
What is this can?
Thanks IO. I'll dig into this once it get my $&@? @!$& new booster and master cylinder installed. Spent over an hour tonight on the cotter pin that connects the brake pedal to the booster. Wow.
Once you've done it a time or too the pin does get easier. Make sure you have the plastic spacer between the brake banjo and the stud on the pedel.
You mean the plastic bushing or a plastic washer on both sides of the banjo?
Yes.... Some Master cylinder banjo ends are different. I've seen a couple that did not have the plastic shim. The one that takes up the slop inside the banjo. If you have it or are even aware the is one there.
Well I had to take mine out as it was so thick I couldn't pin it on that spindle.
Yours isn't stock so I'd expect differances.
Brining this back up so that I can find it later this week when I am putting my stuff back together. Need to reference the pics as I just did my frame swap and I want to make sure I hook stuff back up properly.
