what sealant and primer?
Valdosta GA
86 cj7 4.2l i6 4speed trans
ok so i have stripped the interior of all components and took the paint down to bare metal, removed all beginings of cancer now i was wondering what rtv type sealant people use for the seams in the body and also what is evrybodies favorite primer prior to using a roll on bed liner? i am considering "right stuff" the black sealant used for windshields i have used it in a few other applications in other vehicles but I figured I'd see what you guys like to use maybe you have a better product.
I use Keystone Key Prime 2k urethane primer.It builds well and sands easily.
I'd bet Eastwood would have the right stuff to use on those seams.
I am going to use Penetrol over bare metal and then primer over that. I used Penetrol A LOT when I was in construction. Remove loose rust and cover with Penetrol. Absolutely seals the rust and makes for stable surface for primer. The Flood Corporation makes many products that get the job done like nothing else will! This stuff will be the savior for my hunting rig!
NAPA sells specific sealant for seams. goes on like caulk and after it dries its becomes pretty hard. I used it when I redid the floors in my CJ
