What shroud to use on CJ7 with AMC V8?
10Seconds
Tulsa, OK
1983 CJ7, 258 I6, 5 speed, Dana 300 - for now.
I have a CJ7 with the AMC v8. It didnt have a fan shroud when I got it, but I want to put one back on as I am rebuilding it. Problem is, there are 3 different part numbers I come up with and dont know which I need.
I have a 3 core radiator and automatic Transmission as well.
Any ideas?
Also, should I upgrade to a flex-a-lite or similar fan? Dont want to go electric, but do want to keep this as cool as I can.
Thanks!
Which Omix one did you use?
They list 3 part numbers: 17102.3 17102.1 and 17102.02 and I dont know which is what. One site lists the 17102.02 as HD cooling.
I just dont want to order wrong.
Thanks.
The 17102.02 is for the AMC 258 i6 / 4.2l inline 6. The 17101.01 is a lighter duty shroud. I have never physically seen one, but from the pictures, it looks like there might not be any trimming necessary. I used the 17103.03. It is of heavy construction, with a deeper tunnel for the fan to fit into. I did have to trim to make the lower radiator hose fit, but in my opinion, is a better shroud. When the engine is running, the front of the radiator is like a wind tunnel. I plan to use the same shroud on our 1959 CJ5 . Even though that one only has a V6, I still like the deeper fan tunnel and don't mind doing a bit of trimming.
