what to do??????
what to do??????
Bulldog70
Gadsden, AL
1978 CJ-7: Blue: 258: 3 speed:
I am broke down on the side of the road. Hear is my issue. I press the clutch n and the jeep.will ideal. I let the clutch out in any gear or nutral and it dies. Transfer Case any any gear same thing.
do you have the front hubs locked in and driving around on hard pavement with the Transfer Case in 4wd?
That will cause the drivetrain to bind up and cause all kinds of problems.
I let the clutch out in any gear or neutral and it dies.
It dies in neutral? That sounds like the Transmission is binding. Are you able to shift through all the gears when the clutch is pressed in? If not then remove the top of the tranny and manually move the shift forks into the neutral position and put the top of the tranny back on.
If you can shift through all the gears then it may be something more serious with the Transmission . Removing the top of the Transmission still might allow you to see what's wrong. Make sure you are in neutral before opening the tranny.
could also be a pressure plate problem, try starting it in gear, with the clutch pushed in if it moves, and you can "float" it from 1st to 2nd without using the clutch it is most likely a clutch problem.
stranges thing ever. if i turn the motor over while in gear it would jump. It went dead:mad: evertime I let the clutch out. Yet with the clutch in I could rev it up a far as I wanted to go. This is how I got it to run. I shook all the wires under the steering wheel. I know it was fixed cause it turn over in nutral without the clutch being in. Wiring problens OOOO NO. I drove the jeep for the rest of the day :). No Problems.:cool:
Loose wiring for the ignition switch coming in contact with clutch pedal?
Sent from my SPH-D710 using Tapatalk
