What transmission do I have?
If you still have the stock one if it's a 3sp it would be a T-14 if it's a 4sp it would be a T-18 and the Transfer Case should be a Spicer 20.
If it is stock and a 3 speed, it should be a T15 or if it is a 4 speed a T18. The trans case should be a spicer 20.
See --> http://www.jeep-cj.com/forums/f105/manual-cj-transmissions-12112/
and
-->> http://www.jeep-cj.com/forums/f105/transfer-cases-12108/
It is a 3 spd, and thats what i was thinking it was the T-15 but someone told me that it could be the T-14 so I was looking for something that I could look for to see which one it is. I was also wondering if I should keep the T-15 (if thats what it is) or if i should swap it for the T-18 . I dont know which one is stronger.
A T-18 is way stronger than a T-15 no doubt.
BUT, I have used a T-15 in my '74 during mud racing, and it survived my built-up 360 just fine.
The biggest difference is in the gear selections. A T-18 has a 'granny' or 'creeper' gear in first gear. Not great for mud running at all, but invaluable during rock climbing. But it will not change the final drive ratio ( it will not reduce engine RPM at hiway speeds, no Overdrive )
It really depends on your planned usage of the Jeep.
