what Transmission & Transfer case
Just the fact that you are the original owner is very cool...
Good luck with the tranny/Transfer Case rebuilds....and hang onto her!! Keep it in your family.
I have a 1980 CJ5 with a AMC 304 , 4 speed Transmission . what Transmission (T-176 ) and Transfer Case (Dana 300 ) do i have. they need rebuilt. i got the jeep new, it now has 140k. Transmission pops out of 2nd and some time the transfer will pop out gear
thanks Will
:)Will,
Congratulations on being the one owner............I am also a 1-owner on my 65 CJ w/ 27k miles.
Not hard to do this work if you have the space, desire and tools.
But , If your not into gear work or perhaps do not have the pullers, press & several snap ring pliers available , find a good gear person in your area and get them to do a rebuild.........Most times labor only for the Transmission and Transfer Case on there bench is about $AMC 150 -$200 each.
:D:D:D:D
My 1980 CJ7 has the AMC 258 i6 / 4.2l with the T-176 and the 300 and probably more owners than I can count on one hand. Both leak a bit but I dont have the dough right now to get them repaired.
:)Al...............oil seals if that's all it needs are among the easiest things to replace.
:D:D:D:D
