What U Joint should I choose?
CaseyCJ5
Santa Rosa Beach, FL
1974 Jeep CJ5 304 V8
So I have had the Jeep for a couple of months now and I'm just now getting some time to work on it. I need to replace the rear u joint as it is knocking upon acceleration. i will probably replace the front one at the same time to avoid having to do it again in the future. I have a '74 CJ5 with the AMC 304 . I've looked at autoparts stores online and have seen U Joints priced from $8 up to $67. I am looking for something that will be strong enough for some mild weekend offroading. Any suggestions as to which kind I should get? Any help will be greatly appreciated.
I've always preffered the dana / spicer brand greasable.
There should be "non-greasable and greaseable" I like greasable because I can grease each and everytime before a trip to ensure it's good. Had one blow apart on me at 65mph on the freeway. Dropped the drivline pointing forward... luckily all it did was slap around under my jeep and put a couple holes in the body...
:cool:
There are also different "sizes". I believe (someone please correct me if wrong) the stock size is 1310. Unless you upgrade to bigger driveshaft, or TC output / Pinion yoke input, you'll need to stick with that...
~ Jr
I just put new Dana Spicer u-joints on my machine. The tie-breaker for me was the groove cut into the bottom flat of each stub that fits into the bearing cup. That means that when you grease the u-joint, the grease goes directly to the bearings, exactly where it is needed. Other greasable u-joints that I looked at do not have such a groove
X3 on the Spicer although I use the non-greasable, I think they are stronger for offroad use.
If mine was a road jeep I'd use the greasable ones.
They should be $20-$25 bucks apiece.
Thanks for the input everybody. Sorry I disappeared for a while. It sounds like the greasable spicers are the way to go. Now I get to attack the wiring...
$67 for a U-joint???
:eek:
So I have had the Jeep for a couple of months now and I'm just now getting some time to work on it. I need to replace the rear u joint as it is knocking upon acceleration. i will probably replace the front one at the same time to avoid having to do it again in the future. I have a '74 CJ5 with the AMC 304. I've looked at autoparts stores online and have seen U Joints priced from $8 up to $67. I am looking for something that will be strong enough for some mild weekend offroading. Any suggestions as to which kind I should get? Any help will be greatly appreciated.
I like the spicer greasable. And grease them often. I don't think they break very often if well greased. More often they wear. If you grease and inspect often they last longer. I used to go through U joints much more often. Now I grease and inspect, grease and inspect, grease and inspect and always catch them before they go out.
I am of the opinion that u-joints are supposed to break and the rest of the drive train isn't. especially when you start talking about 78:1 final ratios.:cool:
I agree. Larry, I think you may have been the one that compared U joints to a fuse for the drivetrain. Let it break. It's cheaper and easier to replace than other driveline parts. :D
:eek::eek::eek:
Wow i wasn't looking hard enough! lol
those are some expensive little boogers!
:D:D
Yes I agree with Dave and Larry, the ujoint is the fuse... just dont want the fuse breaking from Transfer Case at 65 MPH anymore... ;)
Though this was totally my fault for continuing to drive it when i could hear and feel a problem somewhere....
~ Jr
I never offer sympathy for self inflicted injuries. :laugh::laugh:
:eek::eek::eek:
:D:D
Yes I agree with Dave and Larry, the ujoint is the fuse... just dont want the fuse breaking from transfer case at 65 MPH anymore... ;)
~ Jr
