What would you do?
powdertwoplanker
Hey guys, was doing a little bench racing today and wanted to see what you all thought.
I have never like the way the cj stops. So was going to add a rear disc setup. Buddy says to swap in a axle that has them already. Thinks it can be done for cheap (with buying the axle) under $500. I said its not that easy and sourcing the axles, doing the work to install is way more work then adding a disc kit to the AMC20 . Plus i have to worry about the axle parts. (Just added one price axles to mine) R & P sells a disc kit for $500
So, would you swap out an amc20 axle for something else. Or just add rear disc brakes? What do you think the minimum cost would be?
To give background, 85 CJ7 with AMC 258 i6 / 4.2l is a daily driver. Sees trails 2 to 3 times month in summer. I don't do crazy. Don't plan to do crazy, 31 inch tires now will go to 33's. Keeping the inline 6. Want lockers at some point.
Scott
Sent from my ASUS Transformer Pad TF700T using Tapatalk HD
Scott
