Which is the right differential ratio?
Chriss
South Germany
1983 CJ7, AMC 360, T176, DANA 300, Axles Stock with true trac, 33" Cooper STT tires, 4" lift by Trailmaster
1999 JEEP Grand Cherokee 4,7 stock. Family car
Hello,
which is the right differential ratio for my CJ7 ?
360 engine
T-150 3 speed manual
33" wheels
AMC20 rear axle and Dana 30 front axle
The old ratio is 2.73 . I think a 4.11 is good for driving offroad too? Or is a 4.56 better?
Hello,
which is the right differential ratio for my CJ7?
360 engine
33" wheels
AMC 20 rear axle and DANA 30 front axle
Here is a chart, so you can pick what is right for you. I would imagine that your old ratio was 3.73
Jeep Ratio Calculators
If you drive it on-road as well I would stick with 4.10/4.11. The 1:1 3rd gear is the main rationale. I would go 4.56 with an O/D tranny. If it is almost all off-road you could get away with 4.56's easily.
Go to www.grimmjeeper.com & enter both combos to see which you think gives you a better range for how you actually use your jeep.
Thanks, but the old ratio is really a 2.73. It´s a 85 CJ wide track axle with inline 6 from California. It is the longest ratio ever build in CJ´s. I believe it was for the stronger pollution control in California?
I have a second pair of small track axles from a 79 CJ also with a inline 6 but from Canada. These axles have the 3.73 ratio.
Ohhh, thank you. What O/D tranny would you recommend? One of my JEEP drivers have a ATLAS tranny in his CJ5 . Is this kind good?
    Best for votes
    on specific items
