Whistling
Whistling
You can also use very soapy water in a spray bottle.
The bubbles get sucked in, and you can see exactly where the leak is.
Why not pull the carb and look for cracks and such?
I did the test like Posi described and it looks like it is leaking from the firewall side of the adapter plate. I get off work early today so I plan on pulling the carb and plates this afternoon and replacing the gasket. Will let y'all know how it goes.
If I haven't said it before I will say it here. Thanks to everybody for sharing their insight and experiences with me on this site. I count myself a pretty decent shade tree mechanic but you guys have helped me diagnose a couple problems that were real head scratchers. I am sure I will need additional help going forward with my in operation rebuild.
I’m wondering if there is wear at the throttle shaft bore causing a whistle.
Is there any side to side play where the shaft goes through the bore?
Agree with Posi on worn shaft holes in carb. A small amount of clay putty can be used to seal the area as a temp test.
Check the carbs base again, with the soapy water this time.
Also-use a known flat-edge to confirm flatness of the manifold, adapter, and carbs base.
Replace the gasket between the upper and lower sections of the carb.
Take ALL the belts off, and give it a go..........
Thanks for the tips. I figured it out. Two of the intake manifold mounting bolts were loose. One about a quarter turn and the other about a half turn. 30 seconds with a 9/16 wrench and my problem was solved. I learned a heck of a lot about the CJ7 vacuum system on the way figuring it out though.
Sent from my ALE-L21 using Tapatalk
Finally:rolleyes:, you ck'd them. :poke: :laugh:
Get the engine kinda warm, and check ALL the manifold bolts again.
Cue the Price is Right loser music...hahahaha.
Glad you got it figured out!
Kind of sad though...I always look forward to everyone else working through their struggles on their rigs. This was a good one. Glad it's not just me!
I am taking the philosophical approach that I learned a lot and essentially have a new vacuum system now. I love my CJ because between this forum and my dad (who has forgotten more about engines than i will ever know) I am learning things all the time.
$35.00
  17.5%
