will my ax15 setup hook to 350?
cjs cj
Petal, ms
79 cj5- 258, dana 300
I got the full ax15 setup, will that clutch setup(linkage,pressure plate,disk,flywheel etc.) Will that work and will the bellhousing bolt up to a 350? Thanks for the help in advance!
It will not bolt up without an adapter. Novak had two styles to get the job done.
subscribed....I have the same tranny sitting in my garage waiting to be installed behind my sbc 350. I havent been able to scrape together the cash to afford the adapters yet.
ax15 is a pretty good tranny but in my opinion,not nearly as heavy duty as a chevy
I have an advance adapters bellhousing to bolt a chevy sb to a jeep ax15. Its an older model but I dont think its ever been installed.
If your interested text me at 405 four eight one 50 five four. It'll be cheap but shipping is on your dime.
comes with a throwout arm but nothing else. Not sure what else (if anything) you would need for it.
Hey pal!! glad to see you on this side of the grass.:D
Preciate it and Looks good but I'm trying to see if I can use everything I've got cause I just upgraded to what I've got
$45.00
  22.5%
