To celebrate the 4th of July, starting today (07/01/2025) all User Upgrades will be reduced by 10% (thru 07/08/2025) To use this special coupon use the code 2025-4th-10percent at check out. If you are already a supporter your existing package will be extended. Thank you for your support!
Like the title says. Will the bell housing in a 67 mustang w/ 289 fit in my 79 CJ7 w/ AMC 304 ? We both have 3 speeds. I found one today and i need one real bad but i have to jump on it today. Can anyone help me out on this? Thanks
what is it you need real bad> the bellhousing or a new engine?
If its just the bellhousing your looking to replace, No I don't think it will bolt to your engine.
If you are trying to put the 289 in your Jeep, it might/might not fit. Go to NovakAdapters.com and read the knowledge base. It should tell you if it is compatible.
But personally I wouldn't put a 289 in a Jeep, unless I wanted to race it. Then I would use a much larger engine anyways...
The 289 is an oversquare engine design, meaning it LOVES to rev, but there isn't a lot of low end to them. I have replaced every 289 I owned (in trucks mostly) with a 302 (or in some cases a 390) and been much happier with the drivability. I did have a Mustang that was 289 powered, and I loved it in there...
