wiper motor & arms problem
chieffatboy
I have an 86 CJ7 . I am having problems with the drivers side wiper "slapping" & getting stuck. It is slapping so hard it is causing the nut on the motor that connects the arm to the linkage to come off. If the blade is bumped, it continues to work right. It seems to work ok without the wipers attached. If both blades are on, the motor is seems to bog down & gets very hot.
Any suggestions. Very
