Wiring for light switch display on dashboard
Rdavison39
Oakville Ontario
1977 CJ7. 304 H. 52,000 original miles.
2010 Wrangler 2Dr
First, should be the same style connector that is on the ground wire in the pic.
If that can't be seen then from the turn signal connector (long and flat and mounted on the column) find the orange wire. Follow that to the splice. There will be 5 wires. One should go to the fuse block, one to the wiper light, one to the splice for the gauges etc, one to the headlight.
Look around the wiper light connector. You may have "lost" it around there.
The wire that always has power is most likely the interior courtesy lights.
Here you can go to view and /or download a color diagram of the wiring.
https://www.dropbox.com/s/4cgv9ke3m2oj70f/2 Interior.jpg?dl=0
