Steering Wolf Lower Steering Column Cartridge Bearing
Black Thumb
St. Louis, MO
1978, CJ-7, 258 Cu In, t-18a, D20
Has anyone installed a Wolf cartridge bearing?
There are reviews and internet claims it tightens up the factory steering and takes out all the slop completely (if your box is tight, your arms are tight, and the rest of the system is gtg).
My steering appears to be as tight as it was from the factory, but that still leaves something to be desired with larger tires at speed. What's "good" in a CJ doesn't actually compare to even cars of the same era. I'm not looking for BMW steering, but I'd like to loose that 1.5" slop if I can. It's $100, so I'm going to jump if no one knows anything about these sealed steering bearings. I will report back once I test drive it.
I’ve got one. Very high quality.
I just ordered one. My steering is also good (as it can be with stock stuff). But this looks like it could even improve it a bit more. A CJ with all good steering/suspension parts is still not modern "rack & pinion" good with a suspension lift and larger tires at highway speeds where I spend a lot of time commuting. I easily do 70+ with no issues, but there is still some minor play/vibration I'd love to reduce. Hoping this adds to the pleasure.
I bit the bullet and bought one. I was shocked at the quality of this piece and how smooth it turns. I almost bought a second one just to have on my desk to spin every now and then. You will laugh when you pull the OEM one out and see what a piece of junk it is. Wheel turns very smoothly and eliminated the up and down slop I had in the wheel. Worth the $$
I’ve had one for a couple of years; incredible piece of engineering. It awaits installation day still.
I agree 100 % Well worth the made in USA
  100.0%
