Build Thread YUKON007's '82 CJ7 Build.
Pulled the trigger on a 4" BDS Lift kit with: add-a-leaf, shackle bushings, .5" shackles, blue shock tubes, and a steering stabilizer. Just doubled by cost to date on the build but I couldn't bring myself to cheap out on something I plan to keep for a long time. Guy up here in Alaska is offering free shipping which is huge and won my business. Hoping to have some more heated garage time in early January to do a little body work and mount the tub.
Transmission and Tcase are headed to the shop for some professional TLC. I'm debating sending in my axles along with them to get the brakes looked at.
I've read up extensively on the AMC20 rear and am still on the fence over it. I did find out its a Limited Slip Trac-Loc with 3.31 gears. Good? Bad? I plan to run about 35" tires and I'll be doing medium wheeling/mudding.
On one hand I can keep it, install a truss: $50 materials, one-piece axles: $250+, and eventually upgrade to an OX locker while upping gear ratio to 4.10 or 4.56. That's $300 to get it to where I'd be with a Dana 44 or a Ford 9". I can snag a Dana 44 for about that but there's another load of info on the swap I'd have to acquaint myself with, and my mind is already reeling from the flood of other Jeep related projects. I'm not going to debate the usefulness of the AMC20 vs Dana 44 with anyone, I've read enough to already despise that topic! :bang: I'm leaning towards keeping the AMC20 , building a truss and waiting till I break an axle to swap in a one-piece.
Current plan:
Clean front axle, POR 15 and Top Coat
Weld in truss for rear axle, POR 15 and Top Coat
Drop off Tranny/Tcase for inspection
Install Lift Kit and get back to rolling chassis.
Mount Engine, tranny, tcase.
Run new brake/fuel lines
Install Tub
Rest
Finish rest of everything else....
The end feels real! Can't wait to have herit back on the road this spring :chug::chug:
If your go'n to 35's(why?). Ditch the OEM axles.
I run 33's with a Ford 9" in the rear. I also run front and rear Detroit Lockers.
The rear 20 is weak and very breakage prone.
With 35s, you want either 4:56 or 4:88 R&P gears.
I wouldn't build a AMC20 from stock to handle 35s. Since you'll already be re gearing I'd look for a Ford 8.8 for the added strength and the benefit of disc brakes. Mine came to me with 1 piece axles and 35s with 3.73. Since I don't plan on re gearing I'm only going to truss mine and see where I end up. I'm Just going with a 4/1 kit in the Dana 300 and keeping my gas mileage at 17mpg. Being a Limited yours should have power brakes wich puts you one up on me. Whatever you do decide just put aside a couple more bucks for a brake upgrade. The difference between stopping 35s as opposed to 33s is significant. From what I've experienced with mine 35s require upgrades that you can usually put off with 33s
I found a Ford 8.8 with disk brakes out of an Explorer. Measures 60" WMS-WMS. Now the plan is to cut down a Chevy Dana 44 , 7" or so on the long side to match the 60" width of the rear. I'll have to convert the Chevy to the Ford lug pattern and re-spline my long-side axle shaft. This leaves me with one custom axle that I'd have to replace in the event of a failure.
My question is, I've already purchased the 4' BDS lift, and I still plan to go SUA. Since the Chevy Dana 44 is set up for SOA will I have problems with my springs interfering with the steering? From the looks of the Chevy D44s, the steering is straight forward of the axle tubes, rather than above and forward. Anyone have insight on that?
I can't find a 74-79 Wagoneer in AK, otherwise I'd be stealing front/rear axles out of that.
Congrats on your axle find :chug: Did you make your outboard mounts or find them on-line?
Made the mounts and bought the spring and shackle hangers from Ruff Stuff. Mounts are made from 1/4" steel and will be both welded to the frame and through-bolted, I plan to weld in spacers inside the frame so I can torque the bolts down hard and not squeeze the frame. I'll snag a picture of the mounts when I get a chance to work on them again. :chug:
Looks great man, awesome project!
