Build Thread YUKON007's '82 CJ7 Build.
YUKON007
Its been a long couple days but the frame is repaired, POR-15-ed and top coated.
Grinding the frame down. POR-15 has a bad rap for not adhering to bare metals but we had little choice. The amount of rust, original paint, and the PO's undercoating would have made prepping the surface complicated. We elected to take a chance and bring it down to bare metal. With Metal Prep and 80 grit sandpaper we shouldnt run into any adhesion problems.
Before: This is the 1/4" angle we repaired with, we prepped and cleaned the surfaces before welding, this is just a test fit.
After Weld: Yea...yea...yea its ugly. But functional!
Before:
After: Used the same 1/4" steel and plated the seams for extra support.
Test fit the 3/8" thick 2.5" tubing. This fit inside the rusted out rear tube snugly. We cut out any rust spots and transfered any mounting holes over. Excitement got the best of us at this point and we made a measurement error on the new leaf spring mounting holes.... They're a 1/2" short, so much for measure twice cut once... Talked with a couple local jeepers and we're hoping it wont be an issue.
After:
Then we moved shop again, to my new garage to complete the POR-15 process. Made a huge mess, but it turned out amazing. We started out with simple green to clean the frame, I had ordered the Marine Clean that POR-15 recommends but didn't remember until after the initial cleaning.
After de-greasing the frame we washed it thoroughly with warm water and hit it for 30 minutes with the Metal Prep. After another wash, we allowed it to dry while we went food shopping for an early thanksgiving with friends.
2 coats of POR-15, first coat we spent extra effort to make sure we hit all the joints and welds. The coats were successive because it took about 20 minutes to lay down the first coat. We finished up the second coat at about 9 pm.
We let it sit for 5 hours and came back to a fairly cured POR-15 frame. Next up was 3 coats of Rustoleum Enamel Gloss Black to serve as a top coat and UV protection. I finished up with that around 3am. Long night but it was all worth it to get this frame back to road worthy.
The orange tranny pan is Frumples reward for tireless hours of grinding, welding, fabbing, washing, and painting. I think it'll help identify the jeep when I sink it in a snow berm or a mudhole. "If you see orange, send help"
Before:
After:
I'm leaning towards keeping the
