Brakes 10" manual adjust brakes parts needed
Bluzharp
Arkansas
1966 CJ5, 225 V6 Dauntless
My new to me 1966 CJ5 has 10" manual adjust brakes. I am replacing almost everything due to missing, wore out, or rusted parts. One of the rear drums was cut off with a grinder at some point and everything but the wheel cylinder is gone. I have searched without any luck to try to locate the lower brake shoe return spring and the wheel cylinder links. I have considered modifying a spring to fit and making the links on my lathe if these parts are not available. Any suggestions for a source for these hen's teeth?
Maybe try giving Bernie's a call. He shows wheel cylinders and other parts on their site (although it does say "Call for availability"). Omixparts.com also lists some of the springs and wheel cylinders as well.
VintageJeepParts.com lists a full kit for your year model, but it shows it's for 9" rather than 10".
Try your local Parts House.
Dohrman makes lots of Replacement Brake Parts.
Several sources have replacement parts for 10” brakes. I just finished replacing the shoes, springs and drums on my ‘72 CJ5 , I had no problem finding the parts.
