151 Thoughts
151 Thoughts
dbirky
White Pigeon
81 CJ-5 151, 4spd
Coolant in the oil will wipe out the bearings. Then why did it blow the head gasket? It sounds like rebuild time or time to upgrade to a 6.
:ww::dbanana::banana:
Full rebuild and have the head and block ck'd for cracks.
X2 on looking for a 6cyl, if the hassle isn't too big with your Smog laws.
Many years ago, I blew the head gasket on a C10 pickup with a 350. Same scenario, lots of white smoke. I did a roadside oil change, and drove it 15 miles home. I only replaced the head gaskets and trued the heads, and the engine ran fine for 2 more years. The oil pressure was still OK, but the engine had overheated to the point of causing oil blow by so I had to add a quart or 2 between oil changes.
That said, I would not do that again. I would completely rebuild the engine, or find a good used one. As already suggested, now is a good time to upgrade.
I'd resurface the head, replace the gasket and put it back together.
Drive it.
It wasn't too many years ago we fixed engines, didn't just automatically rebuild them.
There's a reason it's call the Iron Duke.
Disclaimer: I'm no fan of that engine.
