1975 CJ5 Charging System
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
I have had this Jeep as a project for a few months now and I'm getting closer to actually driving it, but I have no real idea about the Jeeps ( the Witch) history.
When I got the Witch home and was doing a more or less complete inspection it was noticed that the alternator had an internal regulator, this is good. It seems to be a simple affair with a red wire (power) going to the hot side of the solenoid coming out the bottom back and two wires coming out of a plug in the side. The plug wires are black and white. The black wire is wired into the wiring harness, the white wire doesn’t seem to have a home and is sticking out kind of lonely like. After talking to Jeep guru Rob he said the wire is supposed to go to the ignition switch so I wired her up.
This weekend I fired the Witch up for the first time in a very long time. I noticed that the switch seemed to be hotter than necessary and the alternator was much hotter than it should be. Now I’m concerned and considering replacement. Any ideas or help with a proper, simple to wire replacement would be appreciated.
thanks
Michael
thanks
Michael
