Build Thread 1979 CJ7 in remarkable condition!
Very nice! I especially like the "Stealth Clear" paint job..... Almost can't see the body at all!!
Lol now that you point that out it is the best camo paint ever
I dunno - ya might wanna leave it on...... gives it that stealth fighter look !!
Oooh, NICE! That ones gonna be thirsty.. [emoji15]
Had a few hours in the garage tonight.
The new yokes for the Dana 44 and 30 showed so I put in the ubolt style removing the strap style along with new pinion seals and nuts.
I did not paint the new yokes but instead just put some clear on them so they do not rust.
Oh man that's a sweet motor, don't forget that you need a 360 specific flywheel because it is balanced different
Alec, YOU do very nice work!:notworthy:
When you clearance the calpers, make enough room to side a wooden popsicle stick between the caliper and the rim. Why-Rims flex some....
On the pinion nut. Center punch the nut at the slot in the pinion's shaft to help 'lock' it in place. Then use a stripe of red paint from the nut to the threaded shaft as a marker to see IF the nut has moved when you inspect the driveline.
Respectfully,
Respectfully,
I ground off just enough to stick a popsicle between the rum and caliper, and of course repainted the spots!
My torque wrench only goes to 170 ft/lb and I need 210 on those pinion nuts...
Good reason(excuse)to buy another t'wrench........
Think about the cost of the damage that can happen IF that nut comes loose.
lol that's good
I picked a used torque wrench today that covers up to 250 lb ft. Only $20 too!
I would ck it's calibration before use.
Torque wrenches are not the tool, to go the cheap on.
There's no replacement for displacement!! AMC 360 was prepped with a new flywheel and all new clutch components!
I added new motor mounts, brackets, and new V8 frame mounts.
There's still some work to do. I'm swapping out the manifolds for ceramic coated shorty headers, it needs a new power steering pump and lines, and few odds and ends.
Beautiful!!
Just a couple of small things done this weekend.
I installed grounding straps on each side of the block.
I also picked up some differential tags showing the gear ratio. I blasted them and put on some paint.
It's all about the details!
wow dude that looks so good, I love the tags that just tops it off, for future reference do the rounding straps have a vehicle application to be able to search for them?
On the GND straps. May I suggest that you use external star washers, as they 'bite' into the metal for a better electrical contact.
Run a strap from the frame to the main tub also. ;)
$120.00
  60.0%
