1984 CJ-7 wiring harness
diddy2003
Old Time Jeeper
- Western Massachusetts
- 1984 CJ-7
35x12.5x15 MTRs;
YJ 4 inch Skyjacker lift w/ Bilsteins;
rebuilt AMC 360, Patriot Headers, Holley Truck Avenger 670 CFM, Edelbrock Performer Intake, Flexalite Electric Fan; Griffin Aluminum Radiator, Dual Flowmaster Delta Flow 40s;
Dana 30 4.10s w/ Detroit Truetrac;
Dana 60-2 Narrowed, 11 inch Ford Drum Brakes, 4.10s Power-Lok LSD; NV4500; Dana 300 LoMax 4:1 Twin-Stick; Navajo Power Brake Booster
NV4500 gear ratios
1st gear: 5.61 : 1
2nd gear: 3.04 : 1
3rd gear: 1.67 : 1
4th gear: 1.00 : 1
5th gear (overdrive): 0.75 : 1
Engine speed at 55 mph: 1624 RPM
Engine speed at 65 mph: 1919 RPM
Crawl Ratio: 92 : 1
I am looking to replace the wiring in my jeep. Where did you guys get yours? I am trying not to spend a lot of money, but these things look to be pretty expensive. My jeep has been changed a bit, like with all the smog stuff removed, HEI, and I think my carb is from an earlier CJ with no computer smog control on it. Will the changes impact what harness I should get? Thanks for the help. The previous owners of my jeep thought they were master electricians apparently. They weren't . . . .
the bed at the same time, it seems like it might be a good idea to just do it all over, and do it right. Seems like the harness in the jeep has taken a beating since it rolled out of the factory. I will be replacing my electrical sending units with mechanical ones at the same time, but that is in a different thread. Thanks.
