1985 CJ7 FRAME BOLTS- Where can i get them
CJSIT960
babylon ny
1979 CJ7
I am looking for shackle mounts to frame bolts they are grade 5.
Best place to get Jeep CJ7 Bolts. I want to replace all the frame bolts.
Stainless steel bolts if possible
THX
As I recall, they are a 7/16"x14 thread and a 1" length should be fine. Generally, a stainless bolt is around a grade 2 which is a bit on the soft side unless you can get one in a marine grade bolt through a boat shop or on line. I use bolts that are grade 5 or 8 from a local hardware outfit that comes with a cad plate.
7/16 grade 8 can be hard to find. 7/16 grade 5 are easier. Find a good hardware store, not HD or Lowes. I get all of mine from Tractor Supply, doubt you have that up there. Ace Hardware maybe? Stay away from Stainless steel for this stuff like Torx said. Be sure to use some Locktite Blue or Red. I would use Red as I doubt that you'll be removing them again.
Fastenal, Bolt Depot or McMaster Carr if you don't have a local source. I've gotten a lot of fasteners from all three places. Get together a list of everything you need, because shipping can get expensive for a couple of bolts/washers/nuts.
When you install these bolts(No SS here). Coat the threaded area with copper anti-seize and torque to low side of spec.
