Build Thread 1986 CJ7 Build
- Featured
- 3
- Media
- 135
- Resources
- 2
- Solutions
- 2
- Colorado
- 1986 CJ7 Laredo:
258 w/Howell TBI, HEI Ign., Dana 44 Front w/Detroit, Dana 44 Rear w/Discs & Detroit,
NP435 Trans, Dana 300 T-case w/twin stick
1969 Bronco:
351W, D44 high pinon front from full size, 9” full size rear, NP435 trans and Dana 20
Armyvet,
The Wagoneer Dana 44 front is about 4" wider than the widetrack Dana 30 in there now. As you mentioned, since the passenger spring mount is fixed on the housing, if you shorten the long side (driver) about 4", and slide in the spring mount the appropriate amount, it will "center" the housing under the Jeep. The passenger side dimension from spring mount to wheel mounting surface is about the same on both axles.
It's fairly common, if you don't go with the spring out-boarding route.
I'll have to get one shorter inner axle shaft. I'll be using the Dana 30 knuckles and everything on them, since everything is new from last winter. I'll need new outer axle shafts too to make this work, since the Wagoneer's are 19-spline and my current hub setup is 27-spline, iirc.
