2100 venturi 1.08 or 1.14
viking4949
1979 CJ7 AMC 258 i6 / 4.2l 258. Bought with a cobbled together 1.08 venturi autolite carb. Last year, Couldn't get it to idle, did my first ever rebuild, got closer, but still have a slight miss at idle. Had the head redone, fixed the common lifter tick, now have an issue with having to set the idle high to smooth out the stumble. Thinking about rebuilding again, simply because now I understand a little more, and will have some time this winter. Today, I was given another 2100 that has been rebuild long ago. Here is a link to the exact model, but not my carb. C7AF-AS . So now I have 2 questions. First off, should I stick to 1.08 or switch to 1.14 venturi, all other things being equal. I will be rebuilding one or both anyway. After reading some of Elwoods posts, the CFM rating of the 1.14 seems closer. Question 2. I am using an electric choke. I have read other places that the small hole, on the bottom of the carb on the back, choke housing side should be epoxied shut, and could be to blame for the stumble at idle. Is this correct? What should I do?C7AF-AS
Very helpful.
