231 Buick flywheel info
T Williams
Hollister Ca
1962 CJ5, 231 Buick, T18, Spicer 18, Warn overdrive, 5.38 differentials front & rear lockers, power steering, 33 x 12.50 15 tires
I am looking for a little info. I just bought a 62 Willys with a 231 in it, it was a little tired and I picked up another engine. It was an eBay find and the seller didn't know much about it because it was in a storage locker he bought. Now here is my question, the engine I picked up is an odd fire and the one in it is an even fire. I did a little research and from what I understand you can't put a odd fire flywheel on a even fire engine. Can you put a flywheel from an even fire engine on an odd fire engine? The flywheel on an even fire has to be balanced where one on an odd fire doesn't, so I think it would work. An odd fire is externally balanced and even fire is internally balanced. I am trying to get all the answers before I start my engine swap.
The odd-fire would be a neutral balance.You will need to have the flywheel and clutch cover balanced to neutral. you might get lucky not doing this but I don't think it would be worth taking a chance.
